Starting to piece together my setup
  • Starting to piece together my setup
    I just bought this rear setup ( http://zilvia.net/f/showthread.php?t=202150 ), and ordered a set of Tein pillow ball mounts for it.
    Is there anything else I need for the rear (spacers, etc)?
    Also, does anyone know if GC will sell just 2 sleeves and springs (450lb) for the front? In the next few weeks, I'll be placing my order for the front housings/shocks (haven't decided on whether I'm doing an 8611 or 8610 yet, car will be mostly street driven and I'll be trying autocross for the first time).
    I'm open to any other suggestions/options.
    I'm going to go with "no way in hell".
    Look towards the end of the "Update" thread to see what I mean...
      X Eleventy billion!!!
      GC will not piece out ANY of their items.
        Damn. Any other options? I briefly read that veilside was trying to get a new supplier that will sell individually.
        I can't even find used sets of GC kits.
          http://nissanroadracing.com/vbulleti...9&postcount=44
          Also...you can check out ebay for coil over "sleeves"
            AFCO or Speedway
              Awesome. Thanks for the replies!
                Don't limit yourself to 240 parts when you're looking. Many of the sleeves are the same diameter. I picked up a used set of Sentra GCs for $50 once off of ebay. That included 4 springs.
                  If you DD it i'd go with 350f 250r...I DD my car but I attend events 1-2 times per month so I went with 450f 350r. If you have an S chasis I take it you have the uprights for those Koni's? If you find the rates to be too soft you can play with your sway bars.
                  Addicted to Motorsports
                    Yea, I have the uprights. This car is the "toy". I have an 04 A4 for a DD, and also a company car . I think 450f/350r will be fine.
                      Where did you order the teins?
                        www.frsport.com
                        May have paid a bit much, but whatever. They also sell the fronts, but I keep reading that they're designed for stock length struts, so I'll probably be looking elsewhere.
                          I think I'm going to drop the coin on project mu camber plates. It's the easiest way to get the height I want without sacrificing shock compression. If I understand it correctly I'll still be in the sweet spot because the strut will be an inch higher than with the teins
