Camber Plate Bearing Sizes
  • Camber Plate Bearing Sizes
    Lets get a list going on the different plate bearing sizes. I'm going to try and keep in stock the bronze bushings to make the different plates fit.
    Tein 18mm ID Front/Rear
    Deluboz 5/8" ID Front or 18mm (undecided)
    KTS/Project Mu
    D2 16mm ID Front/ 12mm Rear
    Ksport (same as D2)
    Cusco
    Ground Control 5/8" Front
    Bueller...Bueller?
      D2 camber plates are 16mm. I've said that before :P
      The rears are 12mm IIRC.
        :P updated
          Deluboz camber plates have an ID of 18mm, definitely not 5/8".
          The OD of the bearing looks like 32mm, but it's pressed in there, so it's hard to get a hard measurement.
            Hmm.... I thought they were 5/8 since my bushings didn't fit in them, but somehow I think I mixed up my 18 and 16mm bushings.....
              The spacers that came with my Tein rears fit exactly the same in the Deluboz fronts, so I'm gonna go ahead and say they're both 18mm.
                Get a set of calipers ya n00b!!!
                  I have some, but they're at home and I'm at school, and driving with snow on the roads is something I try to avoid.
                    Interesting discovery tonight, the D2 camber plates fit perfectly with the included Koni 5/8" plate bushing.
                      Well 16mm *IS* 0.629" - so I should hope it'd fit. haha
                      I'm really not pleased with the bearings on my K-Sports(same as D2). I know you're not supposed to, but I use some light machine oil on mine to unfreeze them. Sure they'll get gritty at some point, but it was better than a non-rotating bearing!
                        Brian's were actually in better shape that the ones that I had removed from my car a long time ago. Although his car does spend a good deal of time sitting.=p lol
                          I found the measurements for the Cusco/Project mu camber plates. This is the average of 3 measurements with a regular caliper.
                          OD for the pillow nut: 0.750 inch
                            I'm not sure if anyone has seen these or not. Any thoughts? I'd imagine it is basically the same thing that is found in D2s, K-Sport, Megan, etc mass assembled coilovers.
                            http://cgi.ebay.com/ebaymotors/Nissa...spagenameZWD1V
                            They're extremely affordable and brand new, I emailed the guy and asked him what size strut they're intended for/what the inner diameter is. I'll post up when I find out.
                            They also happen to be blue, which happens to match the powder coating on the strut inserts.
                              The ID is 18mm on those.=) There is a few people with them.
