McMaster-Carr P/N for upper mounts
  • McMaster-Carr P/N for upper mounts
    I have done some searching, and I can't find the P/N for the Brass McMaster spacers with shoulders people are putting into struts to clearance down to Konis M14 shaft. For some reason they aren't coming up on McMaster with any keywords I can think of.
    Figured it'd help everybody out if we could get them posted in one place.
    Did you look at the sleeve bushings? They might have something in there that will work.
    Tim
    www.tipengr.com
      Use "sleeve bearing" in the search as Tim mentioned, these are the one's that I used for my build.
        That's exactly what I needed! Thanks guys. Sometimes McMaster can be a PITA if you don't know the exact terminology used for a certain part.
