Oil filters
  • Oil filters
    on my ka24de the bypass valve was broken so its plugged. I am looking for an oil filter and was looking at these two filters but i dont know what it means to be full flow and is there a benifit for a bypass valve to be a lower psid?
    Product Guide LF523
    Descriptions: Full-Flow Lube Spin-on
    Contains: Anti-Drainback Valve;8 PSID By-Pass Valve
    Fits: 2000-09 Honda S2000; 2004 Mazda Miata; Equipment with Isuzu, Kubota, Yanmar Engines
    Replaces: Honda 15400-PR3-014; Isuzu 8-94101-021-0; Kubota 15241-32092; Yanmar 12445035100; Baldwin B179
    Thread: M20 x 1.5
    Product Guide LF240
    Descriptions: Lube Spin-on
    Contains: Anti-Drainback Valve;14 PSID By-Pass Valve
    Fits: Acura, Chrysler, Dodge, Eagle, Ford, Honda, Infiniti, Isuzu, Mazda, Mercury, Mitsubishi, Nissan, Plymouth, Saturn Automotive, Light-Duty Trucks
    Replaces: Chrysler MD135737; Ford F32Z-6731-A; Mazda JEY0-14-302; Baldwin B1402
    Thread: M20 x 1.5
    O.D.: 2 9/16 (65.1)
    Length: 3 1/2 (88.9)
    I looked in the FSM and there's no PSID spec listed for the bypass, but it does say they're replaceable. I didn't find a part number online but it might be worth a trip to the dealer to investigate. The bypass on the engine inlet and the bypass in the filter would bypass the same way, but there may be a reason to have two setpoints.
    https://zilvia.net/f/showthread.php?t=265699
    http://forums.240sxone.com/archive/i...p/t-10075.html
    https://www.bobistheoilguy.com/forum...s_delete,_is_i
    https://forums.nicoclub.com/check-ba...d-t275727.html
    http://nissanroadracing.com/forum/ch...-valve-failure
      I found one for RB motors that's probably the same thing. Read the accompanying text for entertainment value only! ;-)
      https://www.platinumracingproducts.c...-bypass-valve/
        I found the part number for the bypass valve in one of those threads. 15241-40F00
        There’s good discussion about the subject. My take is that filtered oil is better than un-filtered oil, but un-filtered oil is better than insufficient oil.
          You want one or the other. Plugged block bypass valve, get a filter with one and vice versa. I honestly don't think it'll have much impact either way. Use the higher rated PSID filter and one that will hold more oil.
          Don't forget due to my obliviousness when I had the KA S13, I accumulated 70+ hours of racing on unfiltering oil prior to spinning a rod bearing. We won a LeMons race during that time also.
            Originally posted by gills View Post
            You want one or the other. Plugged block bypass valve, get a filter with one and vice versa. I honestly don't think it'll have much impact either way. Use the higher one and one that will hold more oil.
            I agree. The idea of plugging the block bypass and getting a new bypass valve with each filter sounds good, but requires paying attention to filters to make sure it’s there.
