Detonation detection
  • Detonation detection
    Not knowing much about figuring out if your motor is detonating, I've done so e research and it sounds like a microphone and headphones is the best way to do it.
    My plan is to follow an idea I read about taking a voice amplifier and extending the microphone and gluing it to a little battery clip so you can clip it to different parts of the motor and listening while it is running.
    I wanted to tap te collective wisdom in case that isn't the best or someone knows of a better/different way to do it.
    there are schematics out there for doing that with the knock sensor that is already on the motor i believe. but i might be full of it, look around for...nevermind look at this thread
    http://www.starquestclub.com/forum/i...owtopic=127345
    lots of hits typing "knock sensor headphone circuit" into the googles
      I built one of those circuits and it didn't work well under load. I say rely on an EMS with a band pass filter to give you repeatable knock values.
        Interesting...
        Here is an article on the aem ems and knock sensors:
        http://www.enginebasics.com/EFI%20Tu...%20Sensor.html
        And here is the article that got me thinking about this:
        http://www.autospeed.com/cms/article.html?&A=0348
        The second part has the build instructions.
        I like the idea of what you linked to, Tower. don't you have to install the knock sensor? Or just T into the factory location?
        Really beneficial was the audio of the detonation. It didn't sound anything like audible detonation to the ear.
          Megasquirt has a knock detection system that's pretty good and fairly affordable:
          http://www.viatrack.ca
          KnocksenseMS is what it's called.
            I built that auto speed circuit, it didn't work well. It seemed like it had a feedback loop where it kept getting louder and louder. You could definitely hear the valve train noise at idle and light load though.
              I have one of these in my car
              http://www.linkecu.com/products/Tuni...s/knocklink_g4
              Pretty foolproof and by all reports very reliable.
              Sent from my Nexus 4 using Tapatalk
                Hmmm... So you made that??? Man, reading the article, it seems like a microphone and headphones are the way to go and I had high hopes that this could do it.
                The article isn't super new but indicates that electronically distinguishing between detonation and other noises is very difficult, especially at lower volumes. I might still build one and do that ms box too....
                  What's the pricing on that like?
                  I can't find figures on that site.
                    Is the knock sensor on the sr a Bosch unit?
                      Anyone know what kind of knock sensor we have on the sr's??
                        This is also a good option:
                        http://www.jandssafeguard.com/
