AEM Tuning Questions
  • AEM Tuning Questions
    i posted this on aem forums too. figured someone on here can help.
    I can post a screen shot if really needed.
    at 2500rpm, .85 psi, tps @ 65%. O2 is 10.4 and defiantly richer cause the car starts to buck.
    at 2500rpm, .07 psi, tps @ 33%. O2 is 12.7.
    For these conditions they both occupy just about the same cell on the map. the only thing different is throttle position. So then my question is which table do i adjust to fix this. boost comp map.
    when the trottle is above 50% and changing quickly it throws in too much fuel.
    is it the dtps accel table in accleration fuel? tip in is such a bitch to get right.
    I don't know the AEM terminology, but it sounds like you've got too much tip-in. That's probably the tps accel fuel map. You need a little more fuel if there's a fast transient in the throttle, but it looks like you have too much. Where did the settings come from that you have in there?
      the change was from old injectors to newer deachwerks, which screwed everything up.
      someone on aem forums suggested throttle inject correct table. but i don't see many changes made to that in any of the base maps or tunes i have, which makes me think its not usually touched.
      So i made some changes and i go try it out tomorrow.
        The deal with tps accel maps is that, at least with the Haltech I used, it's in milliseconds. If you increase the injector size, 1ms of fuel is now a lot more than it used to be.
