ECU interchange question
  • ECU interchange question
    Wondering if which ECU's are right for which car would be of interest. Thought maybe someone with more knowledge than I could help.
    I am wondering about S13's SR ECU's right now. Is an E5 and 62 interchangeable?
    They are interchangable, in that both will run your SR (as long as it isn't a TypeX).
    The only thing is that the 62/63 is for the Skinny o2 sensor. E5 is for fat o2 sensors. Mixing the two can cause rich condition.
      Thank you, Great info.
        Another thing to consider:
        Any blue connector ECU can be used to power any blue connector harness/engine, so long as the rom is tuned accordingly.
        I have a 1.6 Sentra ECU in my car hehe. Sold that SR one for some cash, and used a junkyard one for my JWT setup
          Not really true.
          Isn't 1.8 Sentra a white plug, as it's 2002/3 and OBDII?
            Originally posted by Epstein View Post
            Not really true.
            ah shoot I meant 1.6!
            doh!
            good spot
              I always use go by the proper part numbers just to be certain.
              Here are all the sr20 ecu's that I have seen...
              S13 SR20DET MT : 50F00 (redtop)
              S13 SR20DET MT : 50F01 (redtop)
              S13 SR20DET MT : 50F05 (blacktop)
              S13 SR20DET AT : 50F10 (redtop)
              S13 SR20DET AT : 50F11 (redtop)
              S13 SR20DET AT : 50F15 (blacktop)
              S13 SR20DE MT : 52F00 (silvertop)
              S13 SR20DE AT : 52F10 (silvertop)
              S13 SR20DET MT : 60F06 (type-x)
              S13 SR20DET MT : 60F07 (type-x)
              RNN14 SR20DET : 54C00 (GTiR)
              RNN14 SR20DET : 54C60 (GTiR)
              RNN14 SR20DET : 69C05 (GTiR)
              S14 SR20DE MT : 65F00 (series 1)
              S14 SR20DE AT : 65F10 (series 1)
              S14 SR20DET MT : 69F00 (series 1)
              S14 SR20DET MT : 69F01 (series 1)
              S14 SR20DET MT : 74F00 (series 1)
              S14 SR20DET MT : 74F01 (series 1)
              S14 SR20DET MT : 75F00 (series 1)
              S14 SR20DET AT : 75F10 (series 1)
              S14 SR20DET MT : 80F00 (series 2)
              S14 SR20DET AT : 80F10 (series 2)
              S14 SR20DET MT : 82F00 (series 2)
              S14 SR20DET MT : 82F01 (series 2)
              S14 SR20DET MT : 82F04 (series 2)
              S14 SR20DET MT : 82F05 (series 2)
              S14 SR20DET MT : 82F06 (series 2)
              S14 SR20DET MT : 82F08 (series 2)
              S14 SR20DET MT : 83F00 (series 2)
              S14 SR20DET AT : 83F10 (series 2)
              S15 SR20DE MT : 85F02
              S15 SR20DET MT : 91F00
              S15 SR20DET MT : 91F01
              S15 SR20DET MT : 91F05
              S15 SR20DET MT : 91F06
              S15 SR20DET MT : 91F07
              S15 SR20DET MT : 93F00
              S15 SR20DET AT : 93F10
              B13 SR20DE MT : 64Y00
              B13 SR20DE MT : 64Y01
              B13 SR20DE AT : 64Y15
              B13 SR20DE MT : 71Y05
              B14 SR20DE : 0J202
              B14 SR20DE : 0J203
              B14 SR20DE : 0J212
              B14 SR20DE : 0J610
              B14 SR20DE : 0M761
              B14 SR20DE : 0M765
              B14 SR20DE : 1M860
              B14 SR20DE : 1M861
              G20 SR20DE : 0J200 (1994)
              G20 SR20DE : 0J610 (1996)
              N14 SR20DE : 68C00
              N15 SR20DE : 0A540
              N15 SR20DE : 1N960
              P10 SR20DE MT : 0A520
              P10 SR20DE MT : 53J00
              P10 SR20DE AT : 53J10
              P10 SR20DE MT : 62J00 (1991)
              P10 SR20DE MT : 67J00
              P10 SR20DE AT : 67J10
              P10 SR20DE AT : 70J15 (1993)
              P10 SR20DE AT : 79J16
              P10 SR20DE MT : 83J00 (1994)
              U12 SR20DET MT : 79E01
              U13 SR20DET MT : 1E000
              U13 SR20DET AT : 4E610
              W10 SR20DET : 95N11
                Also be aware that a COP ECU (such as 50F00 for redtop) is not compatible with a distributor ECU, and vice-versa.
                Cheers,
                Dave
                NismotronicSA Tuning Package/Powered by TunerCodeSA
                Speed-Density Tuning for Nissans
                  Cheers,
                  Dave
                  Welcome Dave=)
                    Does anyone know if a KA AT ECU can run a KA MT rom? Or the two ECU's arent totatlly the same.
                      Yes, you can run an MT bin on an AT ECU.
                      Cheers,
                      Dave
                        Yes, you can run an MT rom in an AT ECU, provided you also use an MT harness. To my knowledge, hardware wise the ECUs are the same, except the AT ECU has the extra I/O for the AT control unit populated on the motherboard.
                        Cheers,
                        Dave
                          I'm looking for the white plug (with a length of harness) that comes on the OBD2 ECUs. Anyone can help?
                          See my blog @ motoredge.wordpress.com
                            It'll work. Just got to jump out the park/neutral switch, or use the circuit to wire up your own clutch-start interlock. If you have cruise control there's some tricks to make it work. I seem to recall reading that the auto ECU doesn't have the speed limiter that's in the Manual ECU.
                            I just converted a 1997 240sx with OBD-II auto to manual last week and didn't swap ECU's.
                            OOPS! I see you asking about ROM-tunes? I'll defer that question to the ROM-tuner types...,
