Bracket for 350Z Track Rotors and Wilwood Superlites
  • Tower240sx
    2fass240us
    are you in need of a real machine shop...PM me
    I'm currently making sets of brackets for the evo and sti to s chassis brackets as well as def's hats and brackets,
    I run an aerospace CNC prototype shop and get to make my own parts on the weekends.
  • 2Fass240us
    That is correct. The Wilwood kit is $60 before discount at Summit. 10% discounts for summit are widespread.
    Excellent point!
  • 2Fass240us
    Just talked to Monty and it looks like unless someone can locate a 10mm inverted flare to 1/8" NPT adapter, one would need two adapters + Z32 lines or the Wilwood kit to run Wilwood calipers.
  • jmauld
    I'm working on the drillpress thing. I'm going to drag Rich to that estate sale this weekend. Drill bits will be next on the list.
  • 2Fass240us
    HAHA. I more meant that I could've isolated the problem to that machine shop or its equipment and taken your sorry-drillpress-and-bits ass out of the equation.
    Really though, I did learn a couple of key lessons. It will be SO much easier this time around.
  • jmauld
    it wasn't a waste since we found out that you should NOT be using that shop to do this work. Plus, I've got these crappy little prototypes that I can promptly shove up your a$$ the next time you're seven hours late!
  • 2Fass240us
    Originally posted by jmauld View Post
    Would you like me to pick them up, do a test fit and then send them to you?
    Thanks, but no. I really wish I'd been able to fit the last pair on my car, but became too wrapped up in the "engine trade." Between that and the issues with the plasma machine, last round was almost a waste. Except of course, you having something to play with and use short-term.
  • jmauld
  • 2Fass240us
    UPDATE: "Sample" parts are getting machined today and will be plated and out the door by Friday or Monday.
    Once I get them, I will test-fit on my car and call in the balance of the order.
  • 2Fass240us
    Looks like I may do an initial run of 30 instead of 10 since there seems to be a decent amount of interest.
    I should have the parts in my hands in 2 weeks or so. I will keep you guys updated.
  • jmauld
    I'm only in if I can mount two 6 piston calipers under each wheel! Front and Rear!
    48 pistons FTW!
  • 2Fass240us
    Originally posted by Colorado S14 View Post
    I will take a pair, will these be for the lug mount or radial mount calipers? When you finish these make something for the rear and I will snag those too! lol.
    These are for lug mount. They'd probably be much more for radial mount.
    I will let you know when I get to the rears.
    -Andy
  • Colorado S14
    Edit: Thought I had an ingenious solution but never mind, the internet kicked my ass.
  • Colorado S14
