350Z steering rack
  • 350Z steering rack
    Is there any reason I should not use an OEM rack from a 350Z in a tube chassis mostly street car I am building?
    I am not real familiar with some of the new stuff and want to make sure it is a basic hydraulic power assist unit....want to make sure a computer is not involved.
    No idea here...any good reason not to use a more readily available older school unit?
      tube frame street car? uhhhhhh...
      just use a manual rack if you're building a tube frame. won't be that heavy.
        I have one with a broken steering arm on one side I'd sell you for cheap
        Looks identical to a 240sx unit except slightly different mounting.
          Probably not...just building it with the same track width as a 350z and using 350z uprights and hubs so figured I would keep it simple...or at least in my mind simple.
            Building a GT1/Trans Am style square tube chassis under a 240z shell. Might do some track days or something but mostly just a street toy...and always wanted to build street legal race car, so here goes!
            Probably won't weigh much more than 2000 i'm guessing but will probably run a 275/35/18 on the front so will have a good amount of tire to crank on. Only two creature comforts are A/C and power steering.
              so what is this off of?
                350Z !! duh
                  350Z !! duh
                  haha...I'm not a 350z guy so didn't have a clue. So does this thing have any wires hooked to it or is it simply hydraulic?
                  I wonder if it damaged the gears? Which side is bent?
                  email me a price [email protected]
                  thanks
