I'm planning to make my own roll center adjustable front and rear LCA's using my stock LCA's and a bunch of chevy parts from coleman racing. There are two options for the taper of the balljoint shanks from them, 7* and 10*. I was wondering what the taper is on the stock s-14 balljoints, front and rear, so I can pick the closest match.
S-14 balljoint tapers?
I think my front stock S13s were 9 degrees, but that was quite a while ago that I measured it.
It's pretty easy if you have an S14 balljoint to measure it yourself.
That or you could just ream the hole out and use a bolt. Will work fine.'18 Chevrolet Volt - Electric fun hatch for DD duty!
Thanks racepar for making this thread.
I was gonna whenever I got around to this site again from yesterday, after speaking with Richard for a bit about that.
So far, mmmb and Def have one school of thought for how to make an adjustable roll center LCA with a spherical bearing and a bolt through it, and Richard has the school of thought with kinda like how Mike Kojima did his on his Sentra.
DING DING DING
Round 1... FIGHT!!
Originally posted by veilside180sx View PostNeither of the Chevy taper stuff will work. You can either ream it out to match the taper, or have soem custom ones made.
I'm not a fan of a bolt for a lower ball joint personally.function > form
It shouldn't be a problem as long as you ream it well, but I agree, if you machine it incorrect a bolt will not be good. But at that point, I'd sure hope you're good with a tapered reamer too because they tend to chatter more than a straight reamer when the angle isn't the same.
I'd personally go with the lower angle balljoint if it were me. It'll be easier to open up the top of the taper than to ream a whole lot more material and open up the bottom(assuming the Nissan taper is in between, which it probably is since 10* is a lot).'18 Chevrolet Volt - Electric fun hatch for DD duty!
Originally posted by Def View PostIt shouldn't be a problem as long as you ream it well, but I agree, if you machine it incorrect a bolt will not be good. But at that point, I'd sure hope you're good with a tapered reamer too because they tend to chatter more than a straight reamer when the angle isn't the same.
I'd personally go with the lower angle balljoint if it were me. It'll be easier to open up the top of the taper than to ream a whole lot more material and open up the bottom(assuming the Nissan taper is in between, which it probably is since 10* is a lot).function > form
I personally...side with the custom route made to fit the stock taper.=)
I have 10 degree Chevy taper ones on my work bench, when I was going to put them on the Sentra.Last edited by veilside180sx; 03-06-2009, 07:27 PM.Between rides...unless you count a WD21...
Originally posted by veilside180sx View PostI personally...side with the custom route made to fit the stock taper.=)
I have 10 degree Chevy taper ones on my work bench, when I was going to put them on the Sentra.function > form
Originally posted by racepar1 View PostI'm actually leaning towards the 10* taper. I am worried that going with a narrower taper will cause the shank to go too deep and I may need to put a spacer between the nut and the spindle on top because I may run out of threads.'18 Chevrolet Volt - Electric fun hatch for DD duty!
Originally posted by Def View PostWhat's the major and minor diameters of the spindle's taper? That'll tell you real quick if you'll run out of threads or not after changing the taper.function > form
DING DING DING
Round 1... FIGHT!!
Originally posted by mmdb View PostIf racepar1 can get some gnarly parts made that'd be a good option rather than spending a grip on custom parts. Racepar1, just be sure to make a bunch of these as people such as myself will need them.function > form
From what research I've done, most aftermarket adjustable ball joints/control arms use a 5/8" rod end.
Why not machine a tapered bushing similar to the Z32 rear ball joint that has a straight 5/8" bore through the center and the "nissan taper" on the outside?
Then you can use a high strength/aircraft 5/8" bolt through the parts to hold it all together.
(see attached quickie drawing)
Those would be cheap to machine and to repair/replace when things wear out.
I would expect the tapered spacers to cost just a couple of bucks for machining, and wouldn't really wear out. The only wear items would be the rod ends and possibly the bolts. Everything else is a non-moving part so they should in theory last 'forever'.
Just some late night ramblings......Attached FilesOriginally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
Originally posted by Matt93SE View PostFrom what research I've done, most aftermarket adjustable ball joints/control arms use a 5/8" rod end.
Even with a redrilled 5/8 hole and a thicker bolt in I was still a bit worried.
My main problem was making the part a "bolt on item"
There is no way I could sell this item and tell customers to drill out their uprights....
Here is a post I made months ago
http://www.physicsforums.com/showpos...40&postcount=1
