Need help figuring out a driveline noise
I have a 97 base model S14 It has 40k original miles at the moment.
it has the stock KA engine; for the past year i have been working on it, on & off.
I started with upgrades by installing nismo engine mounts & Peak perf. trans urethane mount as well as nismo clutch & nissan motorsport lightened flywheel. after doing this everything was cool; no weird noises.
Then i took the suspension apart & replaced all the rear subframe & diff. mounts with the nismo mounts & converted my rear knuckles with z32 units as well as, all new o.e. hubs & bearings.
While i was working on the subframe I also installed a Ishihara crank scraper & verified the engine ran as normal with no abnormal noises.
I also sent my diff. out to have it, regeared with nissan motorsports 4.364 ring & pinion & a new quaife diff. with all new bearings it was proffesionally installed by an X-Nissan motorsport rear end mechanic.
After i installed everything i torqued every bolt & nut to spec. I drove the car & noticed & rattling, almost dog gear resonant sound when deccelerating from any gear between 2k & 3k r.p.m.; while the car is in gear only. I raised the car on a lift & verified everything is to spec. I removed the driveshaft & ran the car in the air to see if the noise is comming from the engine or trans. all good.
I inspected the driveshaft joints & found them to be worn out. Had the driveshaft rebuilt & balanced.
The noise is still there. I am running out of ideas. My next step is to disconnect the halfshafts & run the car in the air to simulate driving; in order to narrow it down to maybe an issue with the diff. setup.
Or maybe thats just how it is, due to the harder subframe & diff. bushings.
Has anybody experienced this???
Please help
If you can make the noise happen in the air, with everything connected, use a mechanics stethoscope to narrow down the noise. But just hearing what you have said, I would put my money on the diff as well.
Harmonic vibration of the diff caused by the springs in the clutch disk being the wrong stiffness. Between 2-3k RPM on decel hits the diff's natural frequency, and you hear/feel it.'18 Chevrolet Volt - Electric fun hatch for DD duty!
Thanks for the replies
when i was still driving the car i installed a B&M short shifter & noticed the rattly sound you guys are referring to; i replaced it due to the noise & also synchro grinding it creates; i used it for about a couple hundred miles. I installed a nismo shifter which is basically like the stock unit except it has harder rubber in the lever.
yes i replaced the center bearing on the driveshaft with an o.e. bearing.
its hard to say if i can feel it, especially having the harder bushings & you know how these ka engines tend to produce certain resonances
but definitelly i can tell its coming from behind me.
also i understand that the noise gets transmitted thoughout the driveline.
Originally posted by 98koukile View PostWho called it? Just in the wrong location haha'18 Chevrolet Volt - Electric fun hatch for DD duty!
hey guys i wanted to mention that originally when the diff. was out & i was having the ring & pinion installed i had a new nismo lsd installed along with it, i pulled the diff out so i could have the diff. guy check the setup because of the noise in question then decided to go with a quaife & here i am with the same noise
