So from reading Richard's threads in the damper section, it looks like all of you that ordered assembled coilovers had long wait times simply because of GC. From what I gathered, it appears that GC is bitchy about ordering separate parts rather than a "kit". I was looking into this kit:
http://www.ground-control-store.com/...hp/II=73/CA=27
It looks fine... Although, I wanted to hear some experience when buying a "kit" lke this. How did GC do as far as ordering a complete kit like this? And I should be able to say (650lb/in, 7" tall spring in front; 550lb/in, 7" tall spring in rear) in the "desired spring rate" box. I also wanted to ensure that the tophat will fit an 8611 damper so long as I select Koni for the shock manufacturer...
Any input is appreciated as long as there is information behind your opinion.
