The first modification I will be performing on my car when I return is a drain of the current 10w-40 high mileage Mobil 1, installation of an oil cooler, and a fill of 5w-40 Redline. Currently, I have a heat exchanger sitting at home that is identical to the exchanger that Def runs. It is labeled as "Tru-cool" on the box. I am kind of questioning whether or not I should use a different core. Setrab seems to have an upstanding reputation amongst most car enthusiasts. I plan to return to the states with a lot of paychecks in the bank considering there is nowhere to spend money in the ocean aside from the internets. I obviously plan to duct whatever cooler I have. Def, I know you have stated that your cooler works well, which does ease my mind some. I just don't want to be tearing this crap apart again in the near future because my oil temps are going up.
The sizing guide that SPL has does not create too clear of a picture as far as what I should be looking for. Obviously displacement/dimensions is about as accurate as you can depict something with numbers, but I am not quite sure what size I should go with. I drive the race line pretty much anywhere I go and floor my car a lot. My track days are normally only these private track rentals which give each participant unlimited track time (virtually) just to give you an idea of the usage of my car. A couple nights out of the week are usually spent doing pretty spirited driving, both straight line and handling, and I live in Florida. The car will remain on 14psi (~350whp) for quite a while.
Any advice/analysis/experience is appreciated, preferably with data/pictures. Thanks!
