A bit of background first....
I'm planning a new suspension setup for next year while winter does its job in the meantime. My s14 will stay a street car with good manner for weekend autocrossing with summer street tires, no track duty. I'm still learning and don't want to blow money on anything crazy that I can't appreciate.
I had Stance GR+ but never liked them. Even with slightly softer rates 7kg/5kg, within 3 months they managed to destroy my brand new rear wheel bearing from just daily driving (upstate NY FTL!!). Damping is quite horrible. I'm hoping the digressive valving of Konis will help.
I'm under the impression that stiffer rates up front like almost everybody runs are beneficial if the car has been lowered to the point that the ugly front camber curve doesn't allow any significant travel. If the stock design allows for example 2" before the strut-LCA angle becomes 90* or more, then lowering by 3-4" won't do any good. So, to counter worsened body roll with 3-4" drop, the solution is using tons of static camber and crazy 600-700lb/in springs. Not my cup of tea.
Questions:
1) My car will only be lowered 1" at most from stock to maintain designed geometry - I'm not spending on correction control arms. I guess that minimal drop will allow me to run softer springs with enough droop. How does 300/300 lb/in sound? Stock springs aren't staggered and car already understeer so why should I? My height drop should keep the LCA from going into the positive camber range, and make use of the slight negative camber gain.
2) I can't seem to find the correct rear motion ratio on 240s. Seems to be about .7, and my rough measurement also gives about that range (measuring RLCA inner pivot to strut mounting point and ball joint). Some people on the other hand have said that rear motion ratio is nowhere near .7, but did not say what number they had.
Questions:
