How much should I ask?
Purchased as a clip 5 years ago for $2,100 + $500 shipping from Cali. The more I got into the motor, the more I realized it would be a good idea to rebuild. I have around $3,500 in the rebuild. Mods are:
0.5mm overbore to 86.5mm
CP pistons, 8.5:1 CR, 86.5mm
new main bearings
GTi-R rod bearings
stock rods with ARP fasteners
ARP mains
ARP head bolts
Cometic HG
3-angle valve joerb
new exhaust valve guides
GReddy rocker arm stoppers
properly-bled lifters
new timing chain, guides, and tensioner
new front cover/oil pump assembly
new water pump
new coolant temp sender
all new gaskets
clean IACV with metal adjustment screw
Nismo thermostat
powercoated valve cover
coolant hose mod to clean up routing
S14SR water neck with -6 BMRS line to T25 center housing
non-smoking T25 with very little shaft play
Most of you guys are familiar with my build and my build threads, and know that I am very anal retentive about stuff like this. The engine does not smoke, and runs very well. No unusual noises or oil burn.
Thoughts?
TIA,
Andy
new main bearings
GTi-R rod bearings
ARP mains
ARP head bolts
Cometic HG
3-angle valve joerb
new water pump
all new gaskets
Nismo thermostat
Thoughts?
TIA,
Andy
