Lowering engine with different mounts
  • Lowering engine with different mounts
    I was about to buy a Dmax hood, which has a cool louvered vent but apparently hits some people's motors. Reading up on this, I discovered these, from Xcessive Manufacturing: http://www.xcessivemanufacturing.com...pid=143&step=4
    They're replacement brackets to lower the motor 3/4". They claim the driveline angle changes by less than 1*. Seems like a good idea, depending on what kind of oilpan to ground/sway clearance you have. Probably would have to modify your exhaust setup though. I have poly exhaust hangers with basically no give, so dropping it 3/4" isn't gonna happen. Thoughts?
    We've used the solid mounts on a few cars, but they were mostly drag or drift cars.
    Rich (owner of Xcessive) is local to me, so I get to play with his toys.
      Oh yea, I had forgotten they were up in the NW too.
      I'm a big fan of window welded mounts, especially since the tired old stockers sag a bit and then the engine is slightly lower. But the window weld fill technique does seem to give a good stiffness level without resorting to poly or solid mounts.
        Now with these and Nismos mounts it will sit normal right? One drops the motor and the other raises it back up
