So I'm making up some misalignment bushings for my S13 toe arms out of some 2024 I've got lying around. The thought occured to me, is there any merit to possibly moving the toe arm pivot forward or aft 5 mm on an S14 subframe? Just eyeballing it, it looks like they made the mounting point wider, but kept the same position(could be wrong on this, just quickly looked at my S13 subframe) - so moving it forward 5mm relative to the center of the toe pivot would restore "S13" toe geometry.
I can put it where ever I want, this just saves me work and it made me think about things when Nissan just made the pivot location wider.
There is plenty of misalignment angle with it moved over 5mm(it's a 50mm wide mounting point, and moving it 5mm either way puts it in the same location as an S13 aftermarket arm).
