Curious if anyone else has had a PS leak like this one I just found... I assume this is due to all heat I get from the T28 on track, especially the one I did with a dying fuel pump (lots of heat off the turbo that day).
I'm getting a pretty good leak from where the lower knuckle of the steering linkage meets up with the gear and linkage assembly. Hard to see in the picture, but top of the picture from under the little metal dust/heat cap. I didn't see any while at track, but after the car sat in the garage for a while I found a good sized PS fluid puddle under the car.
