Differential adjustment
  • Differential adjustment
    Hello,
    I've installed a JUN lightened flywheel on my S13 CA18DET and now my differential makes grinding noise on decelleration.
    Can you tell me how to adjust this ?
    Should I have to adjust:
    - the pinion position in the diff (add/remove shims) ?
    - the ring position in the diff ?
    - both positions ?
    or only the backslash ?
    (It's the first time I have to adjust a differential)
    Thanks,
    Sorry my english is bad.
    Welcometohell38
    It's probably just the harmonics of the drivetrain. Every 240 I've owned with an aftermarket clutch makes the same noise, especially in 4th gear (1:1).
    There's nothing to adjust in the diff that would fix that.
      Yep, drivetrain harmonics.
        Hum okay! Thanks guys!
        Anyway, is it possible to decrease/stop these vibrations?
        4th gear is horrible on deceleration....
        Welcometohell38
          Yes - use a stock clutch disk.
            Welcome to the joy of owning and aftermarket clutch on a 240sx.
            I have asked the same question 5 years ago...
            Basically the clutch springs are too stiff and it causes the diff to resonate when unloaded.
              #racecar, bruh.
              Yeah it's annoying, made even more annoying when you start putting metal bushings everywhere.
                When you get to comically low drivetrain inertia, it'll make a racket on Accel at like 2-2.5 k rpm in 5th as well. More like a vibrating knocking sound on each power pulse.
                  This is why you keep rubber/urethane mounts in the drivetrain. The solid trans and diff mounts were WAY noisier than solid engine mounts. I went back to urethane mounts everywhere and the car is much nicer to drive.
