J30/S15 ABS speed sensor hole
  • J30/S15 ABS speed sensor hole
    Do any of you know whether the abs speed sensor hole is somehow connected to the fluid carrying portion of the differential? I received an S15 differential and broke the speed sensor trying to remove it off my J30 differential to swap it over. Trying to figure out if this is going to be an issue before I finish installing it.
    http://www.freshalloy.com/showthread...l=1#post142490
      Thanks Alex. I came across that thread but must have glanced over that post.
