GK Tech front sway
  • GK Tech front sway
    Hollow 27mm front bar with blade type lever arms and lots of clearance, 3 holes for adjustment. Thoughts? I was leaning toward the Sikky front bar, which is 32mm hollow and includes spherical end links. I have a Tanabe rear which is a hollow 27.5mm bar, they no longer make their hollow front bar. Application is track days, SR car.
    http://www.gktech.com/index.php/s-ch...swaybar-1.html
    http://www.sikky.com/product/s14-240sx-front-sway-bar/
    Is it possible to fit a straight tube through the chassis somewhere? go buy used NASCAR parts and build your own for similar money, and you can replace the bar for cheap if you don't like the rates.
      You can do the straight sway bar - but it's a whole mess of work. There's a lot of crap in the way, so it's a pretty significant amount of fab work, and you're going to go through your frame rails most likely.
      I wouldn't call the cost of a decent hollow splined bar that cheap either. You can find some used ones if you get lucky on the spline count, but I wouldn't call them readily available. A solid bar with enough stiffness is going to be heavy.
        Not interested in that fab project. Leaning Sikky for greater roll stiffness and included end links.
          299 sikky
          Vs
          208 gktech
          Hrm...
            Used NASCAR bars aren't that expensive.. $50-$125 each depending on size/rate. 2ndchanceraceparts.com routinely has piles of them in stock. other places sell them regularly for similar pricing as well. (10 years ago, used NASCAR bars were $25 each... These guys have picked up pricing as popularity of used parts and thus demand has gone up).
