Track tire size for S13
  • Track tire size for S13
    Trying to determine the best track\autox tire size for my s13. Will be running 15x7 +0 wheels. I normally run 205/55/15 on the 15x7's and 225/50/15 on my set of 15x8's street wheels. Most R compound tires that I find are either 205/50/15 or 225/45/15. Which would be best for the 15x7's? Is 225/45 too much tire?
    225/45 is very common on 15x7 in IT classes. Some are also available in 225/50. I prefered the 225/45 since it's a shorter tire and I had the gearing right for it.
    98 240SX SCCA STUish
      225 is actually considered to be a bit wide for 7" wide wheel in 15's. You'll want 8" minimum for a 225, and preferably 9". The car will feel better (transitions, turn in, more responsive) on the 205's with a 7" wheel. Modern tires like some stretch.
        On my 16x8" wheels running 225/50-16's always worked very nicely from a size standpoint.
        '95 240sx
          Definitely 205/50-15 or 205/55-15 on 15x7's. 225/45's need at least 7.5", and that's even tight, while 8" is really better.
            sorry if im thread jacking but what about a completely stock s13 on factory se wheels. they're 15x6.5 my buddy wants to go give a hpde session a try and we have a spare set of s13 wheels to throw some tires on. not sure if he should get the factory size 205 60 15 or something different. and any recomendation on a type of tire (wants to be able to drive on it to the track and back home 250 miles total)?
              I'd go with whatever size gets you pretty cheap tires like 205/50, 205/55, 205/60. Any will work really.
                205/50 is Spec Miata tires. You should be able to find these easy.
                  For what it's worth, I ran the 16x6.5 S14 stockers for a little bit. I did one auto-x with them and with the 5.0 swap they were unbearable. The slightest throttle (motor rated for 215Hp stock, so maybe ~160hp to the wheels?) would cause a spin and not enough grip in the front to help catch it.
                  Right now I'm running 245/45/17 on a set of 17x9 RPF1's with +22 offset. The tires themselves are Maxxis with 430 treadwear so not a performance tire by any mean, but the extra tire definitely helps. Plus, all I did was a mild fender roll and no scrubbing to speak.
