Okay, so I removed the z32 brake shield, but kept the center "mounting plate" which holds all of the z32 ebrake hardware. I had this awesome plan to install this "mounting plate" during the 5 lug swap so that the rear would be all set up for a z32 rear brake swap if that ever became a plan.
Well, all of this "awesome" planning backfired, when I went to install the Rear s14 OEM calipers the other day. I couldn't get the second bolt in. Then with a little coaxing I was finally able to get the second bolt in on the right side. It wasn't until I tried the second bolt on the left side that I realized why the caliper was so difficult to install. This picture is with both bolts threaded into the caliper on the right side:
^the rubber dust boot of the piston was sitting pretty snug against the z32 "mounting plate".
My question is how critical is the outer lip of this "mounting plate" to the structure of this piece? If I were to notch the side out a bit for clearance, would this effect the rigidity of this piece to a point that the e-brake could malfunction? (at this point I'm just assuming that this ridge is providing some structural rigidity, since there are a few pivot points on this piece for the e-brake hardware).
