S15 SR20DET Clutch Options
  • S15 SR20DET Clutch Options
    Guys, I have a S15 SR w/ the 6 speed. What are my options in terms of clutch setups for this transmission? Anyone know?
    Thanks,
    Ben
    The clutch is not the issue as it is similar to 5MT clutch except OEM for s15 is unsprung. However if you want to get a flywheel it does have to be s15 specific due to the difference in thickness from the oem dual mass.
      A great clutch and flywheel combo I am using is the Nismo copper mix clutch with a Toda Racing flywheel.
      Next step it to get the Nismo single plate clutch (with flywheel) its a bit of an expensive option but it works great.
      Another option is to get a "conversion flywheel" say from drift motion in the UK and then you can use any s14 sr20 clutch.
      sigpic
