S13 and S14 OBD1 engine harnesses compatible?
  • S13 and S14 OBD1 engine harnesses compatible?
    Dad has a '93 Hatchback 5MT and has some issues in the harness. I have a spare harness out of a 95 5MT.
    He's using an S13 ECU w/ NIStune..
    Any chance that harness will drop in, or will it take more work than it's worth?
    (If not, does someone have a good S13 engine harness available?)
    They don't swap. S14 harness layout is different and the intake mani plugs are all different, too.
      how much do you want for that 95 engine harness?
        dammit. that's what I was afraid of (and figured). thanks for the confirmation.
        make me a reasonable offer-- not sure what the going rate is for a harness..
          As long as it's a 95 OBD1 Harness the Manifold Plugs and Sensor Plugs are the same.
          Main difference being the 14 not having a connector for the coil as it's internal, having a IAT plug and the MAF Plug being different.
          I'm using a 95 14 KA in my 13 and all I changed was the Temp Sensor to a 13 one for the gauge to read right.
          Main difference being the Body/Dash harness plug.
          Not worth doing IMO.
