So, my new IM setup has a throttle body flanged for a 75m Mustang throttle body (came with a SR performance 75mm mustang TB BTW). The 98-04 year mustang 4.6 are the ones which are compatible
Here is my question: The TPS for the mustang is a simple 0-5V 3 wire TPS. The SR20DET (specifically the #62 ECU) also uses a simple 0-5V 3 wire TPS. Is wiring up another 3 wire TPS as simple as matching up the wiring (ground to ground, 5V to 5V and signal wire to signal wire) and doing a sweep with a voltmeter hooked up to make sure throttle closed is .4-.5 Volts and throttle open is >4.6 Volts??
