I ordered a set of cheapo ebay arms for the rear of my s13 and will be upgrading the rod ends. How loose/tight should the fitment be when placing the pillowball in the subframe mounting point?
The rod ends on the traction arms I got are 4mm wider then both the ruca and toe. There is no way to install the traction rod unless you were to hammer it in (obviously something is wrong here). Both the ruca and toe rod ends fit in their respective places just a little on the loose side. It's been years since I installed arms on my friends car and can't remember how fitment was for reference.
How snug should the rod ends be without the bolts tightened all the way down?
I will be ordering rod ends from midwest control and don't know what sizing to use as the ebay arms seem to be all slightly different.
