Has anyone done this. (I assume someone has). What gauge steel did you use? I have 16 gauge steel sitting around and planned to use it. The reason I wanna cut it out and make it more accommodating is to make engine/transmission entrance and removal easier. Also I'd like to clean it all up and make it simple for my hydraulic brake and pro portioning valve.
Transmission tunnel reworking
You're inventing work, at least with the KA tranny.. pull it off the engine, give it about 1/8 turn for the starter hump to clear, yank it out. not hard.
maybe the SR is harder....Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
From someone who has built a tunnel - don't! Unless you're pulling the tranny in the pits every race and need to save a few seconds....
I'd imagine it would put you into a lot of classes you'd rather not be in as well.
Just make some nice brackets and build some yard art with the rest
Originally posted by Matt93SE View PostYou're inventing work, at least with the KA tranny.. pull it off the engine, give it about 1/8 turn for the starter hump to clear, yank it out. not hard.
maybe the SR is harder....'18 Chevrolet Volt - Electric fun hatch for DD duty!
With a proper jack (read: tranny jack), removing the tranny after all the bolts are removed is a simple matter of tug, locate it on the stand, and turn a knob slowly to tlower the jack while sliding back since (as Def said), the top is essentially flat to allow for this in the SR.
Takes me less than 2 minutes with the jack to pull and lower tranny. Maybe an extra min or two with a KA at the most.
Also, dont forget however to either
a) Lower the subframe for more room or
b) loosen engine mounts to tilt the back of the engine back
c) Just do both for lots of room/clearance.
The tranny jack also works wonders for installation as well as its essentially the same (but reverse) process.
the hump for the KA starter makes it a little more difficult, but still not bad. I've done it enough in the last year that I can pretty much get the trans out in 5 min once everything else is clear. I don't loosen the engine mounts either. when I put the trans back in, I'll have someone rock the engine while I'm stabbing the trans and it goes right together. the only difficult part is getting the trans in place with the car on jack stands.. there's just barely enough clearance to get the trans under the car while it's on the jack, then rotate it so the right side is up and start lifting into place.Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
I used 16ga when making clearance for my Muncie, you may want to go a little thinner 18 or 20ga. I made some incisions in the stock tunnel, hammered it open, and patched it with 16ga. Mine looks rough because I dont care, but it works. Welding into the firewall was tricky. IIRC it was 2 thin layers of steel with a heat resistant (can burn while welding) mat in between.
The problem is that you MUST rotate the trans in order to get it to clear the opening. IIRC, the starter hump hits the trans tunnel on the right side and the clutch lever runs into the fuel & brake lines. If you rotate the trans 1/6 turn or so, it all clears just fine and the trans comes back far enough to lower it strsight down.Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
Not sure how much clearance between the block and firewall is there for the SR tranny, but the KA trans can't come down once it's pulled unless you either rock the engine forward a LONG way or you rotate the thing. since I do this job by myself 95% of the time, I just rotate the trans and be done with it.Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
from that photo, it actually looks worse for the SR, but it could be at a funky angle or something. don't know.
I'm also not sure how much clearance between the block and firewall is there for the SR tranny, but the KA trans can't come down once it's pulled unless you either rock the engine forward a LONG way or you rotate the thing. since I do this job by myself 95% of the time, I just rotate the trans and be done with it.Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
The starter hole is moved around the circumference a few inches on the KA vs the SR.
It may look bad (since it seems the top protrusions extends into the side of the passenger's footwell), but once the mounts and subframe bolts are pulled, both lowered and the engine canted forward, I could simply jack it right into place and when removing, pull it back while I have the jack on a slow decrease (the release BARELY opened).
It was much easier than I expected.
kinda similar on mine, but my tranny jack is a screw-type. no hydraulic lowering available... once I get the trans in place, I'll rock the engine with my feet while shoving the trans in place. it usually works within a couple tries. If not, I go drink a beer to give me some liquid strength and try again.Originally posted by SoSidewaysI don't care what color they are as long as they are LONG AND HARD.
You can stab the SR trans right in. It's contour follows the trans tunnel much better than the KA trans which has the starter hole hanging out where the trans tunnel starts sloping down quickly.'18 Chevrolet Volt - Electric fun hatch for DD duty!
