So I picked up a couple NPT female to BSPT male adapters to use on my Tomei oil block. I opted for stainless steel over the brass Autometer offerings for strength, but either way I seem to end up with a big sender just hanging way out there in space. There are 6 adapter threads engaged into the oil block and 4 sender threads engaged into the adapter when everything's snugged up, however.
I have semi-solid engine mounts and solid poly tranny mount, and the NVH is...substantial.
What do y'all use?
I also tried BSPP hardware to compare, and the adapter offers even less thread engagement on both ends. I suppose the four threads on the BSPP hex head bolt would be enough to block off extra ports, however (the allen head set screw in the pic is the one that came with the Tomei oil block). Amirite?
What do y'all use?
