So I decided to work on my "career" and put my project on hold. Car has been sitting in the garage for 5 years... along with a VQ35HR engine.
I decided I want to finish it but I need some advice. I can't make up my mind if the VQ35HR is worth it, or if I should go an easier route perhaps LS1.
I originally wanted to go VQ35HR being it was a Nissan engine plus I was hoping to lose weight, and gain a lot of power, while still being NA. I was working at a Nissan dealership as well (resources).
Now, I don't have the time or resources I did but after the deployment I should have the money. The problem I'm having is I'm not sure if I should continue with a VQ35HR swap or an LS1.
Problems I'm having with VQ35HR swap:
Hood clearance issues, engine sits too high doesn't allow the hood to shut. (looked into replacing the oil pan to make it sit lower, as well as intake manifolds and more recently ITB's )
Wiring ( debating keeping NATS or removing it, security vs ease )
Speedometer ( ECU reads from differential, looked into doing an S15 speedo setup, car currently has an S15 HLSD, removing 4.63 gearing anyways swap pumpkins?, or something on the lines of GPS speedo )
Engine Mounts ( nobody really makes them, VQ35DE mounts with a spacer to raise one side )
Starter and Steering ( one guy went RHD, another was able to do it.. think he's on this site actually )
ECU (Factory or AEM, etc)
LS1 seems like the swap is much easier, mounts made for it, wiring is easier, fits under stock hood, makes more power and easier/cheaper to make more, less electronic bull****, and mechanical throttle.
Is it worth it? I like the idea of a VQ, but I'm wondering if it's going to be cost effective and more of a headache.
I don't need 500HP, I just want a fun light car for the track. I'm thinking 300-350whp. Ultimately I just want to do some Time Trials, not sure on rules and restrictions for these swaps.
Opinions?
Opinions?
