S15 Vicous & Helical
  • S15 Vicous & Helical
    how can you test a s15 diff to check if its a VLSD OR Helical?
    - Hong
    With it installed? Jack the rear and rotate the tires. Helical = tires rotate OPPOSITE each other
    VLSD = tires rotate with each other
    The bad thing is an open diff will also rotate the wheels opposite each other.
    BTW - did the S15 ever come with a VLSD? I don't think it did?
    If you look at the diff with the cover off, it's very obvious which is which.
      Only the Spec R S15 came with the HLSD.
        yeah they came with a VLSD and Helical. Some guy is going to show me one, but hes unsure. He has a s15 6 speed trans so makes me think its a spec r helical. Pumpkin looks like an s15 but the back cover has 4 bolts like an s13's.... and its not installed so could i just spin the output shaft and it'll be the same as if it was installed? Also if i took off the cover what would i look for? Besides the ring and pinion?
        yessir.
        - Hong
            yeah i didnt understand it at first, they looked the same
            but further inspection
            now i know how different they are...
            open has spider gears
            VLSD is closed with holes
            and helical has that tetris L groove.
            Thanks guys, hopefully this guy has it when i open up the diff.
            - Hong
              Yep, it's super easy to look at it and see what it is when you open the case.
                I keep over thinking things, hopefully its the deal of the century and it is a helical!
                Thanks guys you da best.
                - Hong
