Benefits of side skirts, partially flat bottom and other aero work.
  • Benefits of side skirts, partially flat bottom and other aero work.
    Over the weekend I have been thinking about some possible aero improvements for my s14.
    I’m planning on doing a front splitter/undertray and a wing.
    I’m not ready to tackle all the thermal management issues a true flat bottom would create or the tremendous amount of work and thought required to implement a complete flat bottom.
    I was considering making some side skirts and a semi flat bottom much like the full race s14 below. I've go a sheetmetal brake @ work long enough that i can make the side skirts from aluminum so it not going to be too diffcult a task for me.
    I’m wondering if this partial flat floor like above will yield enough benefit to be worth the effort.
    I was also considering chopping away and flattening out the trunk area like below. I think un-shrouding the back of the wheels, chopping the bumper, and flattening that area out might reduce drag a bit as well.
    Just not sure again of the benefit will be worth the effort.
    I know some one who did similar stuff on a Evo and definitely saw a reduction in drag and improved performance.
      I have thought of doing a similar setup. The only thing I ever hear from people is without a flat floor leading a rear diffusers you won't gain much at all. But I think it has to help keep air out of the bumper and stop the parachute effect it has.
        I imagine a venturi tunnel(s) leading to the rear has a far greater effect than partial undertray like the R14, even if Geoff curved up that rear piece.
          I agree that proper tunnels you be much better at generating downforce. I'm just wondering if somewhat of a flat bottom would yield a measurable benefit. I imagine chopping the rear would reduce the drag caused by the rear bumper.
          I was thinking of this is a baby step before I start working on building proper down force. As driver I'm not sure I'm ready for a proper down force car.
          My motivations are also driven by a desire to make some improvements in the car while it's down for the winter.
            Less drag, more being contained.
            but of course. if you're not in a mega cold area, why not. Unfortunately for me in NY, it's been ****ty since Thanksgiving except like two days when it was raining instead of snowing.
            edit: ya you're in WA... bastard.
              i was considering doing something similar to this and decided it wouldn't be worth it for me. will you get benfits from doing this? sure, but probably very little. I would assume that at some unknown speed the downforce will over come the weight disadvantage. i would say on this one that you would be much better off doing splitter into flat/ or tunneled bottom into diffusser. Of course that turns a weekend end project to a week long project.
                Just making the area flat from the sideskirts to the framerails won't do much.
                You really need a flat bottom leading to a diffuser that starts as early as possible, and maintains the flow attached all the way to the end while running as high an angle as possible (in general).
                  I guess I'll skip the partial flat bottom for now. Ill wait until I'm ready to do a splitter and diffuser.
