Digital Dakota meets q45 ABS
  • Digital Dakota meets q45 ABS
    Finally finishing up my build! VVL+ EFR+ z33 trans = Tons of fun.
    I'm not having very much luck finding details on r200 ABS sensors. I'm 99% sure the q45 ABS sensors the same as the other r200's.
    I am trying to figure out what type of signal it creates and what the sensors polarity sensitive.
    Sent from my Galaxy Nexus using Tapatalk 2
    I would think they're hall effect given the possibility of noise with a VR type sensor.
    I think a scope and probing the sensor with a multimeter will answer most your questions quickly.
      Sounds like a Def answer if I've ever heard one. That makes sense I can't imagine VR being used in this particular application.
      Off to hobo shack to see if they have the batter my multimeter needs...
        haha - I hope that's a good thing that it sounds like a Def answer.
          Not a bad thing, necessarily. Direct no bull answers have their place.
          Just image a freight train vs Geo Metro and should paint an accurate picture. Lol
            OP, if you find out please post up - I have the same dilemma.
              I will posting some more info soon.
                If you want to count the teeth on a stock set of speedometer gears and find out the reduction, then you can calculate the rev/mi on it, then count the teeth on the reluctor inside the diff and calculate the rev/mi on it, you'll easily be able to come up with the step up or down ratio for the dd box to correct things.
                As far as actual signal type, both output an AC signal, the one I used to test a speedometer a few days ago put out 9VAC I think when spun with a dewalt cordless drill, and registered around 50-60mph iirc. It was an S13 sensor.
                  Fwiw, I've heard of people using q45 rear end and speedo output + resistor to get the correction for 240sx speedo.
                  In other words, no Dakota digital box needed.
                    Any luck with the resistor?
