I thought this would be pretty interesting to share. It was on grasroots motorsports magazine website but no longer in the archives:
Basics:
1992 240SX SE Hatchback, original "HICAS Sport Package" model
Engine:
Freshly rebuilt (<1000 mile) Nissan S13 KA24DE engine. Bored .020" over with all new OEM pistons, rings, bearings, etc.
Unorthodox Racing crank pulley
Exhaust side-
Full-Race stainless twin-scroll exhaust manifold
Garrett dual bb GT3071R with .78A/R twin-scroll turbine
All stainless braided lines for coolant and oil routing
Tial 44mm wastegate, 2" dump tube under car
All the hottest stuff has Swaintech "White Lightning" ceramic coating
Stainless test pipe (stock cat available)
Buddy Club Spec 2 exhaust
Intake side-
eXcessive Motorsports intake manifold (8lbs. lighter than stock, removes all emissions ports)
Custom 2.25" stainless piping from turbo to intercooler, 2.5" aluminum from intercooler to throttle body
Tial 50mm BOV
Spearco 2-252 liquid/air intercooler - fed ice water from sealed container located inside passenger compartment
Mangagement-
AEM EMS
MAP conversion with 3.5bar sensor
AEM IAT sensor
AEM boost control solenoid
AEM UEGO wideband o2 sensor
Tuned by Shawn Church in Torrance, CA. Tune is presently set for 109 octane unleaded.
Ignition-
Crane HI-6 Ignition-booster
Crane PS-92
Fuel System-
AMS Fuel system, including aluminum fuel rail, 84lb. injectors, Mitsu resistor pack, Walbro 255lph pump, "relay mod" for fuel pump wiring, Earl's fuel filter, stainless -AN lines throughout
Drivetrain:
Competition Clutch "Stage 6" twin-disc 7.5" diamteter flywheel/clutch/pp system
ATS Carbon 1.5-way limited slip differential
Chassis/suspension:
Suspension-
Koni aluminum double-adjustable high-pressure monotube 2817 front struts, 2812 rear shocks. Freshly rebuilt and revalved by ProPartsUSA for Street Modified in winter 06.
Tein front camber plates and rear pillowball mounts
Hypercoil hydraulic spring perches top and bottom at all four corners
Currently running 750 lb/in front, 500 lb/in rear springs - many other rates available for tuning
SPLParts fron T/C Rods
Powdercoated factory front lower control arms with Whiteline urethane bushings
Largus tubular adjustable front sway bar
SPC adjustable rubber-bushed rear upper control arms
Notched and powdercoated factory rear lower control arms with Whiteline urethane bushings
SPC "Pipe" adjustable rear sway bar (smaller and lighter than stock HICAS rear bar)
Rear HICAS rack removed, replaced with SPLParts Pro HICAS eliminator kit.
Rear subframe has SPLParts solid aluminum bushings and is powdercoated silver
Powdercoated knuckles front and rear
New wheel bearings and ball joints throughout
Brakes-
Stock brake system with Porterfield R4S pads. Functional ABS.
Body-
Front fenders cut and flared with RaceOnUSA carbon flares for additional wheel clearance
Rear quarters cut and re-joined, also covered in RaceOnUSA carbon flares
Wheels and tires:
Complete Custom Wheel (CCW) "Track Classics"-
18x11" front (approx. 20 pounds), 18x12.5" rear (approx. 22 pounds)
285/30-18 front, 315/30-18 rear Hoosier A6 tires, still lots of life left
ARP 75mm 1/2" diameter wheel studs
Interior:
Cobra Suzuka driver's seat
Momo Race steering wheel
Momo e-brake handle
Techno Toy Tuning 75mm steering wheel spacer
Nismo shift knob
Custom designed and fabricated gauge panel with-
AEM UEGO AFR gauge with sensor controller
AEM 19-channel serial datastream multifunction gauge
Mechanical oil pressure gauge
Switches for-
FAL-210 dual electrical cooling fans
Spearco liquid/air intercooler pump
wastegate power on/off
Switches labeled for anti-lag and traction control functions and wired into EMS, but not activated
Odyessy PC680 battery, relocated to rear
Exterior
Original red paint
RaceOnUSA fiberglass vented hood (a little bit hacked, stock hood also available)
Data Management
Race Technology DL-1 data acquisition system with 5hz GPS
Besides basic accelerometer and GPS data, also tied in to AFR, IAT, MAP, Coolant temp, throttle position sensor, vehicle speed sensor, knock sensor, tach
Instrumental in optimizing driver performance in timed events
Spares available if desired
Complete KA24DE longblock on a stand
KA24DE transmission
Engine:
Exhaust side-
Intake side-
Tial 50mm BOV
Mangagement-
AEM EMS
AEM IAT sensor
Ignition-
Crane PS-92
Fuel System-
Drivetrain:
Chassis/suspension:
Suspension-
Brakes-
Body-
Wheels and tires:
Interior:
Momo e-brake handle
Nismo shift knob
Switches for-
Exterior
Original red paint
Data Management
KA24DE transmission
