Converting cluster to read gm fuel sender
  • Converting cluster to read gm fuel sender
    Is there a way to buffer or convert the signal from a gm sender to work with our clusters
    How does the GM fuel sender work? The OEM fuel sender is variable resistance. Spec's are 4.3-5.8 ohms when full and 78.3-84.8 ohms when empty.
      He's talking about the fuel level sending unit.
      The stock sending unit for an S13 is listed at :
      78-84 ohms empty
      4.3-5.8 Full
      From what I can find quickly the S14 is the same
      Depending on the type of the sending unit, if its a swing arm type, you could remove the resistor board and turn it around so that its 90-0, instead of 0-90 like a standard GM unit.
      Or use a sending unit for a pre 87 ford / "most chrysler" which are listed at 73 empty, 8-12 full.
      I guess with a tube type you might be able to install it upside down ?
        Never mind atl will program one for me to read of the nissan cluster that will fit in there cells
