Differiantial setup question
  • Differiantial setup question
    I have a 96 q45 diff with the 6-bolt 30-spline axles setup.
    I wondering if the output shafts are also 30 spline.
    If they are then what aftermarket lsd options are out there for a 30 spline r200?
    http://www.kaazusa.com/lsd_nissan.html
    Q45 diff is the same as the Z32 TT diff, so KAAZ is an option, but they only make a 2-way LSD.
      hmmm
      So my diff options have shrank tremendously...
      I was hopping to find a cheap obx for the r230 and wpc treat it like I did my r200....
      I guess this is the only option for a helical/torsen differential
      Quaife QDF12L ATB Differential....
        Unless you're drag racing or drifting with really sticky tires/big horsepower, I don't think the R200 or the axles that go with them will hurt you any, and by going with a regular R200 diff you open the door to many other options as far as diffs and axles go, both OEM and aftermarket.
          I will be going to local strip quite a bit. The car I'm putting these on should be making around 450-475.
          I have both setups available but I felt those numbers would be a little too close to the r200 limits.
          Sent from my Galaxy Nexus using Tapatalk 2
            Are there any options for cv axles with the 3x2 pattern versus te regular tripod axles? That is the weakest point of the r200 in my experience.
            1992 LS13
            385whp/370tq
              If you're breaking stock axles at the CV joints, then get this:
              http://www.driveshaftshop.com/import...w-6-bolt-inner
              If you're breaking the above axles at the CV joints, you might have to step up to these:
              http://www.driveshaftshop.com/import...-level-5-axles
                Lol at those prices. 999/30 per pair of OEM axles means I could break 67 axles before breaking even.
                I might consider if they were 300 a set.. They are on crack.
                5x1 axles are cv style are they not? There's gotta be a way to adapt the z32 axles to a r200 hlsd.
                1992 LS13
                385whp/370tq
                  Mazworx used to sell an Axle kit but people would break the output shaft... Not sure that's still the case though.
                  Seeing how I have diff and 300zx/q45 axles already it seems to make more sense at this point to just eat it and buy the kaaz or quaife.
