I was considering installing solid mounts on an autox/hillclimb only car but all the available ones I found have a bolt through the center. Have you ever really looked at the stock engine mounts? The are not a straight through in either direction and they are not the same, left and right.
It doesn't follow that the engine would bolt back in the normal spot or bolt in at all. Has anyone tried them?
I didn't take a chance. I made my own but what a pia. Allow lots of time if you do this if you are moving the engine around from the stock location.
Are solid mounts a good idea? I worry what the vibration will do but this car doesn't run long periods at a time so I wanted the solidness of solid mounts.
Thoughts?
Thoughts?
