Tilton clutch cylinder sizing
  • Tilton clutch cylinder sizing
    I have a set of 600 series floor mounted pedals and need some help sizing up the clutch master cylinder, which will be connected to a Z32 trans with a twin disc clutch?
    I was thinking one size larger over the stock size 300zx of 5/8"s.
    So 7/10"s am i over complicating this issue???
    I use a 5/8" on mine with a 6.5:1 pedal ratio, and it disengages about 1.5" off the floor. if the pedal ratio is any lower, then I'd go up to a 3/4" and be prepared to add a pedal stop on the floor.
