Z32 HICAS upright
  • Z32 HICAS upright
    Ok, so I've had these HICAS uprights for years and am starting to get ready to set them up for installation in a planned tear down/rebuild. I was doing some bushing research and ran across this thread
    http://nissanroadracing.com/showthread.php?t=3017
    I knew the HICAS tie rod end utilized a bigger bore than the camber and traction link bushings, but I was unaware that non-HICAS models used the same bore in all three. I want to stick with rubber if possible, so are there any options? Nismo's diagrams list the toe arm bushing as being a separate p/n from the camber/traction bushings (as well as calling it a rear axle bushing).
    Thanks in advance!
    The toe bushing is a different design from the camber and traction bushings. It doesn't have a metal sleeve around its circumference.
    Id bet you could install it just fine in your uprights given the compliance of the rubber.
    That said, non hicas uprights aren't that pricey...
      Aha. I figured they had metal sleeves like the other bushings.
      Concept Z has a good picture of the bushing, so now it all makes sense.
      http://www.conceptzperformance.com/C...5598.166.215.2
        I've got some HICAS uprights that I'm about to install. I just pressed the old bushes out today.
        The toe bush is only about 0.5-0.6mm bigger in diameter than the other 2. I'm just going to use my existing spherical bearings that I have in the s13 knuckles and shim and use some loctite 660 on the toe ones.
        If you're using rubber bushes I wouldn't think that it would make much of a difference.
        S13 Race car, 310 rwkw, Lakeside 55.5, Queensland Raceway Sprint 56.69, QR National 1:17.1
        Sam Collins Motorsport Facebook
        My youtube channel
        S13 Race car build
          Yeah, I don't think the rubber will give me an issue. Since they didn't have rubber in them originally, I was just operating under the assumption that they used the same bushing as the traction and camber bushings. And I hate assuming.
            Can anyone confirm what bushing would work instead of the balljoint?
            Is the difference so small a Hard-Race rubber bushing would work?
