Making fender brace
  • Making fender brace
    Was debating on whether to use 1" square stock or 1" angle and weld. I would think that angle is sufficient if you weld on to make a triangle after welding and it's essentially half the weight of square.
    Conversely, I have this stuff below but it's at least half as thin as the angle or box. I can get all materials for free so cost isn't an issue at this point.
    Thoughts from you engineering folk?
    Go with rectangular tubing.
      Rectangular tube? Aren't tubes round?
      Anyway, what dimensions you think are good? 1.5 x 0.5? 2 x 1? 3x1? 16ga?
        The ones I've seen are made from about 1/2" x 1" rectangular tubing.
        angle iron is heavy and not that strong for what you want because it will twist much easier than tube. it's fine in compression/tension, but not in torsion. add a few other reasons, but the tube is easy to source and easy to cut and weld if you're doing straight cuts.
          Isn't this brace under tension/compression mostly?
            Round tubing is round, but since it's the most commonly used type of tubing, most people drop the "round" nomenclature. Rectangular tubing is the proper term for it - http://www.onlinemetals.com/merchant...=2&top_cat=849
            The more you know...
              BTW - these tubes would not be under torsion, they are primarily loaded in bending in a fender brace.
              Therefore you want a high section modulus for a given weight in the axis it is loaded.
              http://en.wikipedia.org/wiki/Section_modulus
              (oh look at that, they even have the section modulus formula for a rectangular tube listed.... )
                Mostly, yes. But consider the wet noodle chassis that is the s13, and you throw in torsion every time the chassis twists.
                  Its mainly under bending, and essentially zero torsion.
                    got it.
                    and we know that knowing is half the battle...
                    :isee:
                      this is the one imade
                      pretty simple and basic
                        and this a power brace i made
