Shoulder Bushings for Control arm Rod Ends
  • Shoulder Bushings for Control arm Rod Ends
    Hey guys I tried posting on Zilvia, but it seems like knowledge base there is pretty limited when the subject isn't about how low you are.
    So I'm replacing my crappy chinese no name toe rod ends with some Aurora rod ends (Aurora AM-M14T) but unfortunately they did not come with shoulder bushings.
    I would assume they are critical as they distribute the load along with keeping the rod end centered.
    Where do you guys typically get them? I have tried Motion industries and other local parts stores but there is no off the shelf solution that I was hoping for.
    pic of what I am talking about- the spacer ziptied to the rod end..
    thanks!
    You should be reusing the hardware with your existing arms.
      the chinese ones didnt come with them either ><
        The spacers are likely "custom" to that application - so you would need to reuse them.
          oh =(
          Bah, ill just buy some bushings and have a machine shop grind them to spec for these rod ends then.
            I buy them at Kartek but they are baller. Search "heim spacer" in google for tons of results.
            http://kartek.com/Product/Fabrication/Hi-Mis.html
              Coleman CM-9055
                This is a good time to convince yourself you need a lathe. =)
