Oil coolers
  • Oil coolers
    What is everyone running as far as oil coolers go?
    I am looking to get a cooler for my power steering set up, but this is an area I have not previously explored. I found this one on eBay, but, it's EBAY. At the same time, I figure its pretty hard to mess up a small cooler, and if the stock cooling line works, any cooler should.
    What do you guys think? I am mainly just trying to be cheap and save a few bucks.
    Also, not that it says it used for engine and trans oil. IIRC the 240 ps set up calls for ATF.
    http://www.ebay.com/itm/7-ROW-UNIVER...ht_2915wt_1159
    RX7 oem oil coolers have an integrated thermostat. they can be had for very cheap (usually < $50 with lines). FC coolers are about twice the capacity of FD's. Also R1 FD's come with two coolers, which are mirrored, so usually ppl pick one or the other based on mounting.
    Originally posted by Jason M
      I run a small B&M Supercooler. Cheap, wide open so they get decent flow even at low speed, and give plenty of cooling. My oil temps usually hang around around the thermostat opening on track.
        That ebay cooler is the perfect size, and pretty cheap. Do any of you guys have any experience with them? I'd hate to have it crap out on me after only a few miles.
          Used FC cooler can probably be had for cheaper OR spend a few dollars more and pick up an Earls cooler.
            The B&M stuff isn't much more than the eBay stuff, and it has NPT outlets so you're not stuck with smallish -8 fittings.
            I have the ~5x7" core, plenty big enough. I think I paid around $45-50 a while ago
              Something tells me the FC cooler doesnt have an fittings on it already, which would just complicate things.
              Also, Def, I think I love you. (in a non homosexual way, of course....) I also had a question about my cage that I had built, and now needs to be cut out. I wanted to ask you if you know how much angle the main (b pillar) hoop can have, so it can clear my sunroof handle. Should I just PM you? I feel bad about posting all these threads because it makes me seem like I am not doing the research, when I am.
                RX7 coolers take M22 to AN adapters, which are ~$10/each. Setrab makes them, among others (easy to find). I'm using one mainly for the built in thermostat, not because I have an RX7 lol
                I think the FD core is something like 10"x8", FC is like 5"x 24"
                  Can you see the thermostat?
                    Yah it's external, but integrated.
                      Angle on the main hoop? I think most classes keep it to +/- 5 deg from vertical (which is quite a bit). Personally I'd be really nervous with an angled main hoop.
                      I could be wrong on that angle though, I'm not a cage builder.
                        Mocal 19 Row, really nice quality
                        TEAM FAIL RACING
                          On the cage, go to scca.com. click on club racing. On left side is a link to cars and rules. Download a rulebook from there. Build the cage to scca specs and it should be good enough for just about anything but land speed racing.
                            brb, going 500 in my s13
                              the FC oil cooler is made by calsonic. It's a nice unit.
                              but you're looking for a power steering cooler right? that's awfully big for one isn't it?
                              '81 BMW R65
