If your cage builder screws up, then yeah.. the guys that are welding a mondo cage into cars will often put the car up on jackstands with the chassis balanced, which takes the suspension completely out of the equation. for a basic 6pt cage, it's not going to matter much unless you do something really wrong with installing it.
I was under the impression that the frame may change dimensions when the roll cage is welded up?
I can't see the chassis undergoing that much heat distortion. The building tolerance for these cars was probably >1/16" in all dimensions, so you're not going to shrink the chassis that much with a cage, especially if you do it right and mostly tack it then weld joints away from the previous ones.
