Overflow Tank Leaks?
  • Overflow Tank Leaks?
    I have had a circuit sports coolant rez since 2007, the level indicator tube got old and brittle, replaced it with a tube from home depot, same size 1/4, it leaks from the top and bottom very slightly, there is still a 1/8, 1/10th, piece stuck in both black 90 degree ends, i tried taking it out but had no luck, i dont want to damage the teethed ring on the inside? Any other suggestions, let me know if im not being clear
    thanks
    Is your issue with the tube connecting to the overflow tank or the tank itself?
    If its the tank itself, I suggest replacing it with a more durable part... Such as a large can of this finely over-engineered beverage.
    '95 240sx
      those tubes can be metric or standard
      on the nice push connectors they will sometimes have the size on the face of where you push.
        Nevermind fixed it. Can a mod please delete this thread.
          why dont' you share the fix with the rest of us, or was it something you did that you don't want us to know about?
            Yea, why delete? Questions and solutions help everybody on the board.
