Stronger wheel bearings, etc...
  • Stronger wheel bearings, etc...
    Hey guys,
    Haven't lurked around here in a while, sometimes life brings upon you priorities that keep you away from your hobbies.
    I thought about this a few times... but never really came upon a solution, i think racepar1 or def once mentioned a nissan truck wheel bearing bolt in solution.
    I will be going from 255s to 295s all around. With the abuse of a stiff suspension and low offset wheels, the wheel bearings are not going to be any happier.
    So as I was googling I came across this:
    http://www.wilwood.com/Bearing/BearingList.aspx
    http://www.wilwood.com/Hubs/HubList1.aspx
    Is there anything in there that could serve our purposes that would come as close to being bolt on solution as possible?
    The bearings are fine with R-comps. Just make sure everything is torqued down properly. Keep in mind these are the same bearings that came on NA Z32s and early Q45s. Both big cars.
      S-chassis bearings are a consumable in the racing world, but once a season on a frequently tracked car is not a huge deal in the grand scheme of things.
        Spec Miata guys disassemble their bearings, repack them with better grease (Typically Redline CV-2), and put them back together very carefully. I cheated when I had my Miata and just bought blueprinted hubs. I suppose you could do the same with ours; I've not done it but it's an idea.
        http://www.docstoc.com/docs/74620196/Repacking-Hubs
        Also, there's a Word document on this page:
        http://www.tomhampton.info/2010/10/repacking-hubs/
        Edit:
        Dave also did this to his Project Silvia. http://www.motoiq.com/magazine_artic...ike-i-did.aspx
        S13
        1:31.xxx CW/CCW SoW
        1:04.837 CW HTM
        ?? Chuckwalla
        ?? BW13
          Project Silvia used Neo Grease. There's another high quality grease but I forget the name. I'd have to go look for it again.
            http://www.amsoil.com/storefront/grg.aspx
            ^I tried this lithium based series 2000 grease from Amsoil (neo was too pricey) but I noticed it separates pretty bad... I'm not sure it'll last long. Thinking of trying the CV-2 instead... Anyone else use it?
              Since I don't know shyt about grease/lubricants with respect to bearings, could one use something like the Mobil 1 synthetic grease that comes in cartridges for grease guns?
                TRC Paragon 3000 is the Grease I was thinking of.
                  I used Neo grease and re-packed the bearings in the new S14 hubs before I put them on the S13. Doing great with 245 A6's and aero. It's good stuff........but a little expensive.
                  You just have to be careful not to break the plastic retainers when taking the bearing apart.
                  NASA Time Trials TT3
                  BTW I work for Garrett
                    After 'consuming' a hub at a track day in the ITA S13 I sold last year...I bought another used set, repacked them with Redline CV-2...and never had another hub/bearing issue in multiple track days.
                    Running R6's and NT-01's.
                    I'm sold on the stuff (CV-2).
                    - Brian
                      Where do you get the CV-2, and what's the price on it?
                      I'll have the back end of my car apart for a spindle/brake swap soon, so might as well do it.
                        I can get it for you guys. It's about $12 a tube but I can cut a dollar or so off of that, just PM me. It is probably cheaper to locate locally though.
                          only place I know of that sells Redline is a $$$$ parts shop, but yeah it's probably cheaper than mailing it.
                          then again, that's WAY cheaper than the Neo stuff at like $70 a bucket.
                            amazon has it for $12 and free shipping if you buy another $13 worth of stuff or if you have amazon prime...
                            http://www.amazon.com/Red-Line-80402...8131447&sr=8-1
                            '81 BMW R65
                              Would you vote that this is actually worth the risk for the front S14 hubs or no? I took my hubs off to press in new studs and I've floated the question around for taking them apart to put new grease in and pretty much received a resounding "Don't bother, ain't broke don't fix" response.
                              97 Kouki SR 240
