Summary:
Q1: What hoods have the most clearance? (fiberglass or ?)
Q2: When you go top feed and your strut bar doesn't clear, do you have to have a custom one made? What aftermarket strut bars offer the most clearance?
Details: My mechanic is near completion on the installation of a built replacement SR20DET for the SR20DET I already had in my 1989 240sx, (it developed a slight rod knock). My new engine build is on the same Nismo engine mounts I had, but incorporates an HKS top feed fuel rail and Injector Dynamics ID1000cc injectors. My vented fiberglass hood already rode on the valve cover on my old setup, but now with the top feed fuel rail there's no way I am even going to try and put my hood on after looking at how hight the fuel rail is relative to the fender/hood line. I am guessing that I will have to go back to a stock hood but I am skeptical as to whether even tht will work. There has to be an aftermarket option that provides more clearance than the stock unit and is lightweight, with better venting.
Also, once you go top feed do you have to have a custom strut tower brace made or is there an aftermarket one that provides a good deal of clearance? My mechanic said my old Cusco one probably wasn't doing much anyway, but that doesn't mean that I should go without one. The car is a daily driver / HPDE / autocross car with suspension, 17" RPF01s, Z32 brakes, stripped interior, but no cage.
I would appreciate any help offered...
