Delrin bushing sets
  • Delrin bushing sets
    I have access to a Cnc lathe and copious amounts of Delrin. I know of the benefits that Delrin have; but On a street driven car will they hold-up and what would be the pitfalls of doing a Delrin setup. Also once the bushings have been generated in our database we could do individuals or sets for people if they are deemed a good idea.
    Thanks in advance for the input.
    They will last for quite a while. I've had a set on my car for years, but it doesn't see too many street miles. A machined sleeve for the bolt will help them last longer as well. They do need greasing, but they seem to stay low friction for a very long time vs. urethane bushings.
      Unfortunately the only place you could use Delrin in our cars is the RLCA bushings. All of the others need to flex in multiple planes.
        what matt said...and if you are gonna use a sleeve make a nice press fit bronze or oilite bushing that is a slip fit on the bolt diameter...then you don't need to grease it
          Uhhh, don't you still need a slip fit on the delrin to bronze? when you torque the thing down, the sleeve will be clamped inside the mounting tabs and won't rotate. Thus the delrin will rotate about the sleeve..
            hmmm you are right...maybe make a sleeve that slips inside the bronze and have that sleeve be .005-.01 longer so it gets clamped, you don't really want the bronze and delrin to be the friction point...
              ideally, no. but then again I've seen delrin bushings last years on other cars where there's a friction surface.
              but yeah, a bronze intermediate sleeve pressed into the delrin to rotate about a steel inner sleeve would work fine.
              ... or you could just press-fit some 12mm ball bearings into them by that point.
                Mustangs use Delrin bushings all the time, very popular upgrade. Don't exactly remember what the middle metal sections are made of, but they hold up as well as anything else.
                  Yes, I'm talking about RLCA bushings. Maybe I take it for granted, but yes that is the only place you can use delrin on these cars for a suspension bushing.
                  Honestly, you don't need a sleeve as the load is low enough for just delrin (I think the bearing yield stress is in the 10-15 ksi range). It's a good idea if you want to go the extra mile. Make it a slip fit, groove the delrin, and then grease the crap out of it.
                    Can you explain why this is so?
                    Why do they need to flex. And what about spherical bearings that dont flex at all.
                      Thanks for the input; once I get a set made; I'll post em up an give the cost etc.
                        Cool, I'd probably be down. Sounds like the Godspeed rears aren't a realistic prospect.
                          A delrin bushing with a hole in it only allows rotation in ONE plane. All the other bushings on our cars move in TWO planes, i.e. as they rotate up and down they also rotate side to side.
                          A spherical bushing allows rotation in any plane as long as it doesn't bind up.
                          The RLCA acts like the bottom arm of a dual a-arm setup, so you can use delrin there.
                            Im asking "why" they need to flex in multiple planes. I thought that was my question. If I go around dissing poly/delrin on the grounds that "They dont allow our arms to flex on multiple planes" I will get laughed at and they will go "why" which is the same question i think I am asking *scratches head*
                            I wouldnt think you would want the arms to move in multiple planes at all ..just rotate moving up and down.
                            What is it they are doing while going side to side AND up and down ...as in the sleeve and the bolt are actually supposed to be twisting into the bushing? and this does what exactly ..what is the arm trying to accomplish during this
                              What he's telling you is that every arm, except the RLCA doesnt strictly move up and down in its range of motion, and will cause binding, making it a waste of time for the other bushings, the RLCA is the only application where it makes sense.
                              I'd be interested in a set, I did a bunch of drawing with the emachineshop stuff to see about getting sets made a while back, just never bothered with going forward with it since.
