Hey guys. Was wondering if anyone had some specs I'm looking for on the KA24DE Valve Springs. Here's what I'm looking for:
Spring Inner Diameter
Spring Outer Diameter
and Rate if possible
Main reason I ask is I've seen it pip up more then once that the KA Valve springs can be changed out for CA18DET and VG30DE(TT) valves srpings. Main reason I want to know is I'm trying to find a low budget valve spring upgrade that will allow a KA to hold 7500+ RPM with boost without a problem. I've seen guys claim 7500rpm N/A but all those claim that are running stock came which are no more then 248 duration and 9.4mm of lift. Cause if the CA and VG spring interchangeable rumor holds true then VQ springs would work which if stiff then stock KA springs which I would assume. You can get a set of new ones for $65 for 16.
CA, VG and VQ (Along with a few others) have spring dimension of 27.5mm Outer and 20.0mm Inner diameters.
Thanks in advance guys.
