Saturday, at the track, I had to luck of having one of the prestone hoses under the intake manifold come off( I must have screwed up when installing it.
Mind I was participating at a drift event for the first time and I wasn't much paying attention at my dash. Until I smelled prestone and looked at the temperature gage showing the line at the end of the scale....
I parked the car at my spot and shot it off and the heater was cold, so I knew it was missing colant . At that moment, I shot the engine off and started looking for the leak.
After fixing the leak, which took me 1h(letting the engine cool and trying to reach that horrible area, I started the car just to realize that my exhaust fumes are white. (insert !)
I was able to drive back, but found some mayonaise in the catch can.
I took the engine appart today( well head at least)
This is cylinder no1. All 4 are the same. they seem to have leaked from the water passage nearest to both the cylinder and the exaust.
What bothers me is this.
I rebuilt this engine and I didn't get the head planed BUT I mesured the deflection with fillergages and a straight edge just like in the FSM.
Could it be my fault or its normal that if fails in that certain way?
Should I still get the new head planed? Or I can still get away by measuring?
The reason I am asking this, is because I found metal 2 weeks ago in the oil, the engine seem to by bass a lot and I don't have general confidence in my mechanical skills of 2 years ago and that bottom end doesn't seem to be in good shape..( the engine was built at that time)
Could letting it sit outside in the engine bay ( on asphalt) cause any problems to the engine? I always did an oil change before the drive of the car. Could have it lead to the weakening of the head gasket?
My fault, or not totally :P.
