I don't have any experience effing with a pinion, so thought I'd ask. Was dropping in the LSD tonight after getting the right shims finally, but after I installed the diff, there was a wretched sound when turning the pinion. Took out the LSD, and the pinion bearing sounds like crap, like a clinging sound, which wasn't there before... There also feels like some resistance/dragging when I turn the pinion w/o the LSD in there. I just squirted some 10w in it to see if it helped; the sound mostly went away but the dragging persisted. I cleaned out the diff housing with a bunch of toluene earlier in the night, but I highly doubt that would eff up the bearing.
Think it's worth it just to replace the bearing since I have it apart now? I can't see any metal shavings or loose rolling elements, just the sound and drag.
